Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
Thread: 4agze Questions...
    Oct 2005
    Thumbs up
    4agze newb questions...
    1. What size exhaust are most people running on theres?
    Mine is 2.5" with a cat, muffler, and tip and its WAY loud...
    2. How much power do people have?
    My AE101 4agze puts down around 145hp atw with intake, cooler, exhaust.
    3. Does any one ever have problems with belt slippage?
    What sort of belts do people run apart from stock?
    4. Lastly, what sort of power are you making on the street, ie: what cars have you blown off
    Just always been an N/A 4age boy, so im new to all this forced induction stuff.
    :2thumbs:
    callum
    qld
    tully
    2.5 inch exaust. front mount. nevo supercharger pulley (15psi of boost). few other things. 150 proven hp at the wheels (probly more by now) my exaust is much quiter than my 4age in my ae82. beats most r32,33. commos which are the usual suspects, one of those turbo galant things. thats bout it really. lookin to go turbo.
    your friendly neabourhood electrition. for cash jobs pm me!
    Jun 2009
    Michael
    My old GZE had 2.5" exhaust, small front mount and microtech, made 122rwkw on 8-9psi. Depends on what muffler you run, I never had a problem with it being too loud.
    Veteran slide86's Avatar
    Huw
    Hills
    belt slip is a big problem that i had on my mates ae92 GZE. in the end i just did the tensioner so bloody tight i thought it was going to snap, but its been like that for 4 years and havent had a problem
    i have a 2.5 inch exhaust with one muffler and it was pretty loud, will be doing something bout it. remember tho, s/c engines have to pump alot of air out the exhaust with nothing to dampen it like a turbo engine. that makes a difference
    Dusty
    Lynbrook
    2 3/4 i think mine is one muffler and a cannon, had a silencer too but it sucked way too much power so going to be putting a decent muffler on it once its back on the road.... only had one dyno run with a silencer in it and massive vacuum leaks... i made 80kw :unsure: haha..... but haven't ahd the opportunity to go against many imports but will eat any commodore for example gen 3s.... and keep upo with a VX GTO till 140 i think it was..... and i haven't had a problem with belt slip on my car, and its just a normal 5rib belt, but you can get this stuff called belt grip... but it makes your belts very nmoisy
    Oct 2005
    Sweet info guys, keep it coming...
    Mine is proven to 145 hp atw... Standard Pulley.
    Senior Member DavisJD's Avatar
    Im running a 2.25 inch exhaust, with a resanator and a muffler, its pretty loud but I dont mind.
    Running aftermarket ECU, front mount, extractors, standard pully, has been dyno proven to 125rwkw. But every dyno is going to be different.
    I get a little belt slip when its cold, but doesnt last long.
    Have beaten S15's, with pod filters and exhausts. Dead even with a Pulsar GTi-R to 200, exhaust, boost controller, freshly rebuilt. stockish V8 commodores and falcons. worked S14, various rice burners!
    Bassically, it will be quite competitve, and will come down to how you get off the line!
    Dusty
    Lynbrook
    and i can sometimes keep up with james' car :lol:
    Oct 2005
    Not too bad for a little 1.6 with a s/c plugged on the side...
    Seems that belt slippage is pretty bad atm, can you hook up a boost guage anywhere to check?
    yer ive just got my car started the other day. its got a AE101 map 4A-GZE with trd copy extractors, 2.25" exhaust, cat, resistor and muffuler. i want it as legal as possible. and it sounds really nice. front mount ic, standard pulley and standard ecu. and from the info sounds good as well.
  1. Questions about my 4agze
    By Mickey H in forum Technical - Questions
    Last Post: 12th April 2009, 06:06 PM
  2. 4agze questions
    By Ipswitch06 in forum Technical - Questions
    Last Post: 14th March 2006, 09:29 PM
  3. 4AGZE Questions
    By Poobrown86 in forum Technical - Questions
    Last Post: 2nd October 2005, 09:53 AM
  4. 4agze questions
    By Jonny Rochester in forum General Topics (No Technical Questions)
    Last Post: 28th September 2005, 09:48 AM
