Results 1 to 10 of 11
Thread: brakes
    Veteran deleta's Avatar
    Callum
    Queensland
    Wynnum
    hey spent a bit of today trying to bleed sneek and squueks brakes
    they wont bleeed its like theres an air leak of some crap. when he pumps the brakes with no valves open it bubbles. so i think the is a problem there.
    any help would be very much appricated
    thanks callum
    Aaron
    In the Mountains
    front or rear...?
    if they have been disscounected/rrun out of fluid then there maybe alot of air in the lines or the master/booster may be stuffed
    Dave
    more info man!!!
    if there are any leaks ANYWHERE in the brake system theres no point even trying to bleed the brakes
    where do you see the bubbles?
    - Blaise Pascal
    Callum
    Queensland
    Wynnum
    ya i cant see it leaking any where, there are bubles in the resofwar when u pump him in the peaddle. and when u are bleading the brakes there is like this big gap were no fluid comes out when u pump.
    Ryan
    qld
    brisbane
    Aust.
    bubbles are comming from the brake booster.
    basically what happends is, i pump the pedal, callum loosens the nipple, air comes out, keep repeating for ages, and its still not getting less spungy.
    a bit of a background.
    before we swapped in another diff the brakes were shmick. then when we swapped the diff. we were able to keep the drivers side drum, but we used the other drum that came with the new diff. obviously, after this the brakes needed to be bled, as they were spungy. note: we only changed the passenger side rear drum.
    now, it seems when you try and bleed it, its sucking air in from another location.
    Senior Member DRFTR86's Avatar
    Richard
    South Oakleigh
    check if your passenger side wheel cylinder isnt leaking, sounds like you a got alot of air in their tho, get a bottle, get a peice of rubber piping in the lid going all the way to the bottom of the bottle, poke a breather hole in the bottle, make sure the rubber bit fits tightly on the nipple, open the nipple and pump the pedal, this allows no air to go back in the system but only fluid to come out
    PROTEK TYRE AND AUTO
    SQ ENGINEERING
    NCCE
    Callum
    Queensland
    Wynnum
    yah its not leaking, i reckon the master cycelender is rooted
    Veteran biggo's Avatar
    Nick
    Noosa
    i had the same problem with the resoviour bubling.
    i threw a brick on the pedal once its pumped tight then bled them while the brick was still there.
    worked very well.
    Sounds like something is rooted, probably master cylinder. You are doing the right thing.
    EIDT - Removed crap, thought you wre bleeding the clutch
    Nick
    Qld
    Brisbane south
    Aus
    if the seal on the brake master is rooted is should be leaking around where its bolted to the booster...mine leaked inside into the footwell. Have you taken it off recently? if so did you bleed from the booster down the line (ie bleeding at each join in the line starting at booster and working down to the nipple)
    it doesnt sound like an airlock though...moreso a rooted master
  1. Jdm 86 brakes (swap for RX7 brakes)
    By Shitbox in forum Cars or Parts Wanted
    Last Post: 2nd July 2012, 06:32 PM
  2. brakes
    Last Post: 11th May 2010, 02:04 PM
  3. tough lsd diff.. brakes to brakes
    By rad32 in forum Cars or Parts Wanted
    Last Post: 16th December 2009, 09:39 PM
  4. brakes
    By bart in forum Technical - Questions
    Last Post: 11th June 2008, 12:52 AM
  5. brakes
    By HiLtOn in forum General Topics (No Technical Questions)
    Last Post: 16th February 2007, 01:20 AM
