Well this sucks to do but i'm putting up for sale or EOI (depending on offers i get).
This is coming out of my crashed KE70 that i only had running for 6 weeksi spent alot of time on this and it was done properly. really sad to have to do this.
This is a COMPLETE (eg. nothing missing!) package to get this 4age running in your KE70,AE71,AE86 over a weekend.
Included: Everything in the pics is yours.
JDM aw11 4age bigport - low kms (would be under 100,000kms, very, very clean and smooth. no smoke at all.
engine includes all accessories. low mount alternator, sensors, intake pipe etc.
cut and shut TVIS inlet manifold.
factory jdm exhaust manifold with heatshields
Modified ke70/ae71 loom. ADM ecu. all wired as per factory.
T50 gearbox and tailshaft to suit borg warner.
Brand new exedy heavy duty clutch kit installed 6 weeks ago.new fluid etc..
thermo fan system. running ke70 radiator and st162 celica fan. wired as per toyota factory.
Any crossmembers you need/hydraulic parts (master/slave cylinder. clutch slave cylinder is fitted with proper line to clear aftermarket headers or factory headers.)
Brand new Bosch VL commodore fuel pump and lines/fittings (see pic)
Before starting the engine (6wks ago) it was fitted with BRAND NEW:
dissy cap
rotor button
synthetic oil
toyota oil filter
topgun leads
ngk plugs
fuel filter
air filter recharged (k and N)
timing belt
accessories belt
red nulon coolant
injector o-rings
fuel pump
Location: croydon, near ringwood. Eastern suburbs, melbourne.
Price and payment: ...
Can see running.
I can remove all the parts you need to fit in your 70/71/hatchi
After just doing this conversion, i know exactly how much this costs. To get all these new parts and strong engine/gearbox and clutch you cannot do this for under $2500. I will happily argue this with anyone.
A workshop will charge you over 4k to get a conversion done with less new parts. (eg. toyospares)
will consider offers on the whole vehicle. (has chassis damage)
Contact: Andrew. Pm for phone number or reply here.
Any more questions, pics etc just ask.
thanks
