Results 1 to 3 of 3
Thread: 20v timing
    Veteran dr1ft-pig's Avatar
    Brendan
    NORTHSIDE YO
    hey all pretty simple question but im too dumb to know the answer
    now when u put your motor to "top dead centre" and put the head back on, there are marks on the cam cover that you line up to marks on the cam gears
    now my question, there are 2 marks about 1-1.5 cm away from each other on the inlet cam gear, i just want to know which 1 i line up with the mark on the cam cover
    thanks, brendan :2thumbs:
    MY JZX83 (clicky)
    is the mark a dot or a line
    are the two marks similar in appearance and position, ie on the edge of a tooth on the gear
    turn the inlet cam over so the #1 had just closed for compression ready for ignition then power stroke
    whatever recognisable mark that u use on the exhaust cam gear, use for the inlet
    put up a picture of this inlet cam gear
    Brendan
    NORTHSIDE YO
    ok ill get a pic of it this arvo, im busy as fuck atm
    MY JZX83 (clicky)
  1. 20v cam timing
    By NIZLAH in forum Technical - Questions
    Last Post: 29th July 2009, 09:21 PM
  2. 20v timing belts
    By lstylr in forum General Topics (No Technical Questions)
    Last Post: 26th May 2008, 11:55 AM
  3. 20v cam timing
    By b1gb3n in forum Technical - Questions
    Last Post: 13th April 2006, 03:35 PM
  4. 20v timing belt
    By DRFTAE86 in forum Technical - Questions
    Last Post: 15th March 2006, 03:25 AM
