Results 1 to 10 of 11
Thread: aw11 4age
    hey everyone i have scrapped the ca18 idea for legal reasons and i have sourced a 4age from an aw11 mr2 , i need to know if i can use a remote thermostat housing like people do on front wheel drive motors to convert it to rear wheel drive ? also if anyone has anything else to add about changing from mid mount to FR your help would be much appreciated. cheers :2thumbs:
    Veteran biggo's Avatar
    Nick
    Noosa
    same as fwd motor except for rear water outlet
    cheers , so will i need the flat type rear water outlet still ?
    Aaron
    In the Mountains
    i know that you can use fwd rear water outlet on rwd aplications, i dont know if this is diffrent from aw11
    cool man i already knew that , but i'm pretty sure there's 2 types and one is no good with a remote themostat housing setup.
    i was told to use an ae82 flat type one , i guess i'll find out which one it has when i go check out the motor
    i have another option : a jdm 4age with everything except the loom and ecu , can i use a front wheel drive loom on the jdm motor ?
    Veteran driftism's Avatar
    Andrew
    Watsoia
    You will need to change or modify the rear outlet on the head, the MR2 one sticks out straight and hits the firewall, but either a FWD or RWD one will work fine.
    And yes, you can use a FWD loom with any motor, so long as it is a bigport 4age.
    Aaron
    In the Mountains
    a FWD loom it too short and needs to be lengthened, or is can be mounted in the engien bay but i would really not recomend this due to the heat and the shit that flys around in there (water, oil, fuel etc...)
    cheers for the help . :2thumbs:
    Veteran v-tec's Avatar
    Grant
    Gold Coast
    Hey mate i use a aw mr2 motor, pretty sure its just the same. Just got a remote therrmistat, and i dont think loom is any different. One thing tho is the timing is set up alot different on the aw motors to standard bigport
    Nick
    Noosa
    loom itself is fine only certain parts ie sensors need lengthing
    and yes the timing is slightly different
  1. 1989 aw11 mr2 4age
    By sld sho in forum Cars for Sale (Toyota Only)
    Last Post: 8th December 2012, 05:07 PM
  2. Aw11 4age
    By foamy in forum Car Parts For Sale
    Last Post: 1st August 2010, 10:36 AM
  3. aw11, ae92, ae101 bits and peices WITH PHOTOS, mainly aw11 things.
    By spanielmr2 in forum Car Parts For Sale
    Last Post: 1st January 2009, 08:59 PM
  4. aw11 4AGE convert to RWD
    By SNAP in forum Technical - Questions
    Last Post: 1st July 2005, 03:57 PM
