Results 1 to 10 of 14
Thread: 4agte opinions for killer oil smoke
    ok gte engine last comp blew radiator hose ran hot for a bit, head checked ok bottom end unknown damage, head replaced with trd metal gasket motor back in run fine untill under boost blows copious ammounts of oil smolke. engine out check compression 150psi even all cylinders, only difference im running the engine rocker cover breather straight back in2 the inlet mani instead of a catch can. I run na 4age rocker covers on this motor, smallport head bigport block so oil return gallery in back of head blocked.
    ok first thought of mine rings got soft from getting hot, blowbly, not aplicable 150psi compression.
    2nd thought too much oil in engine incorrect dipstick fitted checked not applicable.
    3rd thought na rocker covers have different breather setup??????????
    4th thought not enough oil returning to sump due to oil return in head blocked off???????????
    5th thought why is there so much oil in the top of the motor???????????
    6th though no turbo is near new just been checked and is fine!!!!
    give your thoughts people im extreemly lost here????
    Veteran slide86's Avatar
    Huw
    Hills
    does the engine breather have a one way valve in it?
    if not, there will be boost entering the engine and forcing it (oil) into the cylinder somewhere.
    tried disconnecting the breather and going for a run?
    Greg
    Coorparoo
    probably a really dumb idea, as i dont know if its even possible..
    but a crack in the oil gallery, letting oil seep into the cylinder under pressure?
    that makes extreeme sense!!!!!!!!!!! but engine is out of the car and i couldnt of driven it on the street anyway!!
    Huw
    Hills
    ^ which idea
    ive seen a diesel jackaroo with a cracked oil gallery. too months to figure out what it was
    engine breather idea!!!! both head and block have been insopected and are in excellent cond!!
    AE71 Rolla
    Number five is a dead give away. The breather from the cam cover has to run into a catch can or just straight to the atmosphere. I have been told that when you run it back into the inlet manifold it pressurises the top and bottom of the piston so the oil that is pumped up cannot go anywhere. i had it setup like this for a while and one time when i opened my bonnet the entire engine bay was covered in oil as it all came out of the dipstick from the pressure build up.
    did u get any problems with the smoke though??
    AE71 Rolla
    Yeah i did. When it came on boost it just pumped it out
    thanks very much for the info i guess that was the problem!!! spuing i went to the drift practice and did 2 laps before i put it on the trailer and went home what a bummer!!!
  1. 4agte no oil cooler
    By 17zon in forum Technical - Questions
    Last Post: 13th August 2012, 05:22 PM
  2. my new 4agte blowing lots of white smoke
    By Nic19 in forum Technical - Questions
    Last Post: 14th December 2009, 06:46 AM
  3. 4agte turbo blowing smoke..
    Last Post: 9th February 2009, 10:12 PM
  4. smoke from oil catch can breather holes
    By Brendo in forum Technical - Questions
    Last Post: 15th May 2007, 05:35 PM
