Results 1 to 10 of 13
Thread: From Drum to Disc brake
    parrot
    You need a T18 rear half of tailshaft, buy the correct handbrake cables that connect to the calipers, get the small cable that actually fits to the handbrake lever out of a SV11 camry.
    Unbolt the rear links and tailshaft and remove the s series, bolt in the T series and the rear half of the tailshaft from the T18. Change the oil in the diff.
    Connect the rear brake hose to the diff (which is the same as for the T series), rebuild your calipers and install the correct brake proportioning valve which sits under the brake master cylinder.
    Bleed brakes and away you go.
    Simple.
    Senior Member ae86 drifter's Avatar
    Pete
    hey parrot so the SV11 bridge cable is shorter then the 86 one????
    ROYAL GARAGE NEWCASTLE
  1. Rear drum to disc brake conversion!
    By Mikeylimiter in forum Technical - Questions
    Last Post: 10th July 2012, 12:23 AM
  2. Disc brake conversion bits for T, S series drum brake diffs.
    By Hen is a total nutcase in forum Car Parts For Sale
    Last Post: 26th July 2007, 01:31 PM
  3. Disc brake rear end vs Drum brake
    By Lappy in forum Technical - Questions
    Last Post: 21st January 2006, 05:35 PM
