Results 1 to 5 of 5
Thread: VL fuel pump..
    hey all,
    i have converted my ae71 4a-C to a 4A-GE JDM bluetop.
    I have a VL high pressure external pump ready to install... is this the only pump i need, or will i absolutely require a secondary pump? I'm unsure if the VL pump is substantial for what i need (note: i am not using swirl pot)
    thanks all. all comments much appreciated.
    Kane
    it would be recommended to have a small lift pump, to feed to the vl pump coz they suck at sucking
    im not sure on wat specs on the lift pump but im using a low pressure high volume one,
    ok, so if i have the VL pump near the tank, a smaller external pump with more sucking power should be installed closer to the tank? the VL pump just won't do on it's own?
    it will, but fuel surge will occur more frequently, yeh best bet is get a small universal pump and chuck it in the lines, with a small carby fuel filter before it, and then the vl pump, then a bigger efi filter,
    or once i saw someone get a vl intank lift pump and put that into the ke70 tank, which feeds to the external pump
    57YLN
    alreadys been explained
  1. Vl Fuel Pump For 4age Conversion
    By ke70 xx in forum Car Parts For Sale
    Last Post: 21st July 2009, 09:20 AM
  2. vl fuel pump VIC
    By tuff te-72 in forum Car Parts For Sale
    Last Post: 30th May 2009, 04:43 PM
  3. vl turbo fuel pump
    By HiLtOn in forum Cars or Parts Wanted
    Last Post: 8th August 2008, 01:49 PM
  4. External Fuel Pump (VL)
    By thanhngo in forum Car Parts For Sale
    Last Post: 5th November 2007, 02:02 PM
  5. Vl fuel pump
    By GZE KE70 in forum Car Parts For Sale
    Last Post: 8th May 2007, 01:42 AM
