Results 1 to 10 of 12
Thread: Engine Overheating
    Senior Member Fozz's Avatar
    Nathan
    Gold Coast
    Hi Guys
    I have a 2t carbied motor that keeps overheating. Ive checked the water pump and replaced the thermostat and flushed out the radiator but it still overheats. somebody help please. i dont have a clue whats worng and i need it fixed as its my daily driver.
    Elite rthy's Avatar
    Leo
    Tulla
    BHG?
    Ryan
    qld
    brisbane
    Aust.
    if you take it on the highway, sit at a lowish rpm will it continue to overheat? if so, there is a blockage somewhere. generally with a bhg if you keep the revs down and going at a half paced speed it wont overheat.
    Nathan
    Gold Coast
    My car has a three speed auto when im on the highway doin 100 its at 4000rpm anyway know matter what when ever i drove it always overheats.
    Senior Member 350hp4agte's Avatar
    underwood
    qld
    jimboomba
    does it use alot of water, is there oil in the water or is there water in your oil sounds like a blown head gasket
    Dave
    yes this is a good idea!
    also check your timing, i hear that to advanced timing can lead to to much heat.
    also do you get any water vapor out the exhaust, in extreme HG failure, this will happen
    also do a compression test, that will tell all.
    - Blaise Pascal
    Nathan
    Gold Coast
    I checked for bubles and now i know that i dont have a blown headgasket but i still have cooling issues. ill probably have to take it to a mechanic cos i want it running for the qld cruise. thanks for the suggestions guys.
    cheers :2thumbs:
    Senior Member SLO-030's Avatar
    Ryan
    Southern 'burbs
    How old is the water pump? Whats the radaitor condition? Like are all the fins on the rad good and not weak? so if the push on them lightly they dont break.
    Thermostat have you pulled that out and checked it in hot water? Radaitor blocked?
    Abit more information would help heaps...
    When you at lights does it get hot then when you start moving does it get cooler? Or at lights it cools down and when your moving does it get hot?
    Little info like that will help
    bass_2000_au_au@hotmail.com says:
    they see me drivin....a 30....neons blaring....#####s lookin dirty....look at my dirty 30
    Nathan
    Gold Coast
    It starts to heat up if im at the lights if i drive it normally at night time it stays at normal temp but during the day it overheats. i have a new thermostat which i just fit yesterday and my waterpump is fine. The radiator is a bit old but seems ok and i also replaced the thermostat housing gasket and waterpump gasket. Thats all the info i got.
    sounds like it copuld be a blockage somewhere
  1. Engine overheating and smelling of maple syrup
    By camkore in forum Technical - Questions
    Last Post: 6th February 2012, 02:35 PM
  2. Brakes overheating
    By flamingheads in forum Technical - Questions
    Last Post: 10th December 2009, 08:23 PM
  3. 4k Overheating
    By flynnske in forum Technical - Questions
    Last Post: 15th October 2009, 08:20 PM
  4. ca overheating help me.
    By slipps in forum Technical - Questions
    Last Post: 23rd May 2008, 08:56 PM
