Results 1 to 6 of 6
Thread: SOLD - Pls Delete
    Thumbs down
    Pair of coil-over threaded collars & springs -$100 SOLD!!!
    Condition: New in box!
    In SA: Postage available Aust. wide ($20)
    Was going to use for coil-over conversion - but got T3/Ground Control now.
    What they is:
    Example of similar set up on Kaizen's Coupe:
    Elite rthy's Avatar
    Leo
    Tulla
    whats the inside diameter?
    they are aluminium arn't they?
    spring rate?
    free height?
    Collars are Aluminum, on a normal front strut you'd need to weld a steel ring above and below the collar to fix it to the strut.
    (unless you have an race-spec Aluminum-alloy strut ) for rear conversion you'd will need to clamp/bolt these to shock.
    ID Spring: 65mm
    (ID Collar: 52mm)
    Yes.
    450lb = 8K
    7" = 180mm
    Thumbs down
    Also Available seperately:
    7K Springs (Pair) - $60
    Coilover type ID=65mm, Free Height=170mm.
    Condtion: used but perfectly good. Black.
    Thumbs down
    News Flash# SOLD!!!
  1. SOLD - PLS Delete
    By goldke70 in forum Car Parts For Sale
    Last Post: 6th May 2008, 12:59 PM
  2. SOLD - Pls Delete
    By 741 in forum Car Parts For Sale
    Last Post: 16th November 2007, 03:49 PM
  3. SOLD PLs delete
    By ae86driftstyle in forum Car Parts For Sale
    Last Post: 31st May 2007, 12:32 AM
