Is your starter motor attached properly? i.e not loose? :huh:
Hey all,
How are you? I am having issues starting the car. It always starts first go but I have noticed when my car is on an angle when parked and trying to start it it wont start. Does anyone know what could be the problems?
Thanks
"Impossible is not a declaration, it's a dare..."
the float in the carb might b stuck and floodin it
^^ Agreed, would be a carby/fuel flow issue if its a 4AC. Let us know what engine it is first
What angle does the car not start on? ie nose down, nose up? And how much fuel is in the tank when this happens?
4AGE is here! Cheers 44GTE and Anthony for your help! http://www.ae86drivingclub.com.au/fo...ad.php?t=10384
AE86 Driving Club Official Rules -please read!
What am I doing right now? Twitter me!
Thanks guys, no my car is a 4age 16 smallport. Definately not a fuel issue guys. Also the nose is up when it happens.
i have the same issues. my car (especially when cold) is always stubborn to start.
my car has a big fuel system in the boot so i always wait for the pumps to finish priming b4 i give it a crank over..
the strange thing is that when i turn the engine OFF the pumps continue to hum away for maybe 6-7 seconds after it is of
Insert witty comment here....
I have jdm fuel tank so pump is internal if that helps. Yes mate, that what it is like with external fuel pumps
if ur car is on a angle and wont start it could mean you have low petrol or not enough and since the car is on a angle the fuel pump cant pick it up..
Could be the fuel pump is not working too well ie not enough pressure
