Hey mate you will have to unbolt the two bolts rightunderneath the strut.
You will find the strut sitting on top of the streering arm which is what it is bolted to.
You should be able to lift (note i say lift) it off once those bolts are out, might take a bit of persuaision, but yer should come right off
You will also have to remove the brakes somehow, you can either undo the fluid line or there is two bolts that hold the caliper onto the disc which you can unbolt if you plan on keeping those brakes.
Hope that helps a bit
