i just started an apprenticeship and we did a head today![]()
you need to get new ruber gasket for rocker cover and d rubers (back of cam) if there not on the actual gasket , new camshaft seals , new head studs(must be correctly lubed to get torque settings right) , and one thing i was tought today is to put some high grade silicon on each corner of the rocker cover to avoid leaks (this is what they do in most factory's and they stay sealed for ages) also use dolamite spray on gasket stuff when using metal head gaskets and replace timing belt if it has any sign of ware . i'm just a first year so i might have missed somethin , good luck :2thumbs:
