Results 1 to 4 of 4
Thread: fuel tank questions
    Senior Member darkon's Avatar
    Shawn
    ACT
    Canberra
    my fuel tank has a leak. a big leak. big enough that my car guzzles fuel like a twin charged v8 and kills grass like crazy but not phsyically visible if i had to guess where it was id say it was hidden by one of the straps supporting it. no welding fuel tanks or BOOM so how would i go about fixing this? second question. i wanna put a poly fuel cell. like one of those plastic things. was thinkin 61L. firstly how hard are these to get setup. can anyone give me some information on the conversion? also are these lighter then standard fuel tanks? any help wuld be great thanx guys
    Elite rthy's Avatar
    Leo
    Tulla
    you dont need to go to all that effort, I found out the easy way to clean a tank a while back:
    take the filler nozzle off, chuck some detergent in and then hit it for one minute on all the insides with a high pressure hose. Empty it and your done, I know because I worked a few times on mine
    parrot
    I had a similar problem. For some reason there was a very small crease in the top of the tank that resulted in a tiny split.
    This was sufficient to lose quite a bit of fuel, plus stink out the car. It was only visible if you took the tank out and shook it around with some fuel in it. You would then see then a patch of wetness spread around the area of the split. I covered this with some blutack like fuel tank repair putty, cheap at Repco. Seems to have done a good job but have since replaced it with another tank I picked up cheap. I put some small spacers under the straps to reduce the crush factor (?) on the tank.
    Shawn
    ACT
    Canberra
    sounds great so far guys thanx. im pretty keen on the fuel cell tho i have this "mods over repairs" policy where if something breaks i put in a hi performance item instead. eg my clutch fucked up n was replaced with a 5 puk button. so im curious how much lighter they are n if there are any other advantages to them?
  1. in tank fuel pump with inbuilt surge tank
    By NIZLAH in forum Car Parts For Sale
    Last Post: 18th September 2012, 08:43 PM
  2. WTB, AE86 JDM style Fuel tank ( as in EFI Tank )
    By Lexsmaz in forum Cars or Parts Wanted
    Last Post: 1st August 2010, 10:20 AM
  3. for sale , surge tank, aus fuel tank, hood linning + more
    By hillclimb86 in forum Car Parts For Sale
    Last Post: 20th June 2007, 12:20 PM
