Results 1 to 9 of 9
Thread: 4 link settings
    Stefan
    Parkinson
    i just installed my 4 link rear end now my tailshaft is vibrating hella of alot and it dosnt feel safe
    what can i do to resolve this issue
    i loosenes the tail shaft rubber and re tightened it
    but its making a loud whiring noise
    and when i change gears it make a big clunk
    Site Supporter Javal's Avatar
    Josho
    I'm going to assume that when you say 'i just installed my 4 link' that you have just installed adjustable trailing arms / panhard rod.
    The only reason it would vibrate alot is if all the settings were out of whack.
    Make sure both the upper trailing arms have exactly the same length, and the lower pair too.
    Infact just try adjusting them to the stock lengths and see if the problem is still there.
    Also make sure your diff is centred.
    Also note that if you're now using fully rose-jointed/pillow-ball links, you no longer have rubber bushes on the ends of the arms to isolate vibrations from the diff/pinion/crown wheel. All these will be transferred directly to the chassis now and cause a shit load more noise inside the car even when properly aligned!
    Rob
    Moorabbin
    ^ i have already told this to dippry
    he wants the rose joints but doesnt want the added nvh
    then he should get the Cusco ones which are Pillow-ball on the diff end and Normal Bush at the Chassis side!
    Oldschool Member
    Aug 2007
    mind you, whats nvh mean???
    Jul 2009
    Kane
    Coburg
    duuuude wtf is with your sig? LOL
    Senior Member kaibeecee's Avatar
    Pete
    Could be bad pinion angle.
    take out the arms, and precisely measure them to be of the EXACT same length as your stock arms. this will be a starting point until you wish to alter the arms (and the inherited pinion angle) for your driving style.
    if they're fine, be a man about the NVH (noise/vibration/harshness for the ones that don't want to google it.)
    Stefan
    Parkinson
    it is measured and seems on now ok some measurment and tuning required
    and the wanker i work with fuked around with my profile!
    but now he resigned!
    good ridence to bad filth i say!
  1. Unusual Watts link design + general watts link discussion.
    By slide86 in forum Technical - Questions
    Last Post: 14th July 2011, 06:58 PM
  2. Torgue Settings?
    By gumbie in forum Technical - Questions
    Last Post: 9th June 2009, 11:21 PM
  3. What settings are you using?
    By Slimer86 in forum Photography & Digital Design
    Last Post: 14th February 2009, 11:23 PM
  4. timing settings?
    By ONI86 in forum Technical - Questions
    Last Post: 25th November 2006, 09:21 PM
  5. torque settings
    By hoyin3132 in forum Technical - Questions
    Last Post: 12th July 2006, 08:31 PM
