Results 1 to 4 of 4
Thread: urgent: removing rubber boot of lca
    Ryan
    qld
    brisbane
    Aust.
    hey guys
    need some quick help here
    how do you remove the rubber boot covering a ball joint on a xt130 lca?
    some mates said you cant do it, others have said just grab a screwdriver?
    anything more specific ?
    both of mine have punctures in them... obviously considering the boot themselves are cheap as, id rather replace them whilst they are out.
    cheers guys.
    Site Supporter Javal's Avatar
    Josho
    You have to replace the entire ball joint, not just the boot.
    Use circlip pliers / 2 screwdrivers to remove the circlip, then press it out.
    Some people find removing the circlip easy, myself, i find it exceedingly difficult.
    part number for the ball joints (just from any steering specialist) is BJ145 from memory, but it would be best to doublecheck
    yeh there the ones i used, and removing the ball joint is easy coz u dont need to worry bout breaking it so jsut hit it out, getting th enew ones in however is a nother story, which is y i havent got corona lcas in my car yet
    Veteran driftism's Avatar
    Andrew
    Watsoia
    You can buy seperate rubber boots for the lca's. Go to repco and ask. they have generic ones that will fit.
  1. Wtb 86 boot rubber seal
    By Gear-head in forum Cars or Parts Wanted
    Last Post: 11th June 2012, 11:17 PM
  2. T50 Gland plate bit that hold rubber gear boot onto the floor
    By Shitbox in forum Cars or Parts Wanted
    Last Post: 1st September 2011, 10:48 PM
  3. KE70 Rear end cut off + rubber boot seal SA - Adelaide
    By troyboy in forum Car Parts For Sale
    Last Post: 30th December 2010, 02:49 PM
  4. removing LCA's
    By Wanabe_Garage in forum Technical - Questions
    Last Post: 17th December 2007, 04:20 PM
