Results 1 to 8 of 8
Thread: JDM loom -> ADM ECU
    Aaron
    Vic
    Ballarat
    Hi guys, been scratchin my head for a little while over some wiring issues. The loom I have was being used with a JDM ecu but I have an ADM AE82 ecu. Ive pluged em together and the injectors dont, well, inject! how can I make the JDM loom work with the AE82 ecu?
    Thanks
    parrot
    It is something to do with the injector firing sequence.
    Not sure if you can resolve it easily. I reckon much less trouble to just get a JDM ecu.
    Aaron
    Vic
    Ballarat
    Dont the injectors fire all at once?
    It's the power for the injectors, Cross the terminal on the ecu BF with B+ and it will work.
    justin
    Hills District
    hope your injectors dont fire all at once
    they fire in sequence depending on where the pistons are
    Aaron
    Vic
    Ballarat
    Yeah I tryed that, but the injectors still dont seem to fire. whats the best way to prove if they are firing or not?
    I think they do fire all at once, If you look at a wiring diagram they are all wired together, so there is nothing to make one fire without the others firing too.
    Aaron
    Vic
    Ballarat
    Do you mean that I should cut the BF wire and put +12v to the BF ecu pin, or just bridge the B+ and the BF at the ecu plugs and leave everything else?
    If I just bridge B+ and BF i get +12v at both sides of the injector. Is this right????
    Bridge it.
    Both sides of the injector will have 12v.
  1. Replies: 2
    Last Post: 19th March 2012, 01:24 PM
  2. wtb 4age jap or adm ecu and loom
    By pen15 in forum Cars or Parts Wanted
    Last Post: 14th January 2011, 11:15 PM
  3. Syd jdm 4age/loom/ecu/adm t50
    By corknose in forum Car Parts For Sale
    Last Post: 2nd August 2010, 05:14 PM
  4. Swaping ADM Wiring Loom with JDM Loom
    By joshcris in forum Technical - Questions
    Last Post: 20th September 2007, 03:18 PM
  5. ADM ECU on a JDM loom
    By Brenton in forum Technical - Questions
    Last Post: 15th May 2007, 05:41 PM
