Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
Thread: REVERSING xr4'S
    I want reverse my rear wheels- SSR xr4's-= 15x6.5 +6. Can this be done? I know this has been covered before but most people are talkinmg about meshies. Any pro's/con's I need to know.
    Cheers-Rohan
    stefan
    vic
    eastern suburbs
    meshies= 2 peice wheels! just undo the millionbajillion bolts and reverse them
    Stefan
    Parkinson
    cant be done due to being seemwelded in middle!~
    same with most ssr aka speed star rims!
    cant with long chump rims or the mk 1 2 3
    Senior Member kaibeecee's Avatar
    Pete
    you can't 'reverse' them per se', though you can change the width/offset. but it's expensive as you have to get custom outer wheelstock rolled. not to mention it involves lathing off the weld and bolting a new outer on.
    not to mention the procedure would be illegal.
    really, just keep your eyes peeled for high offset longchamps on yahoo or ebay.
    Veteran johl's Avatar
    Johl
    sexy longchamps inside-
    ssr very deepdish-
    Stefan
    Parkinson
    check mine i have 5 inch of dish on my 9"" long chumps
    Veteran Bustin_86's Avatar
    Justin
    North-West Coast
    I have some ssr mesh that has been reversed on the way to me. When i take delivery i will be checking out how they have been done so that i can hopefully advise everyone else with the secrets lol!
    Just looking at it from a logical standpoint (i have never actually seen how the inners are welded to the outers) one would think that it is possible to unbolt and grind/lathe off the welds, flips the inners, use a high tensile bolt and then stitch weld the inner back to the outer. While this may not be "legally safe", as with all of our modifications i think that if you exercise a bit of common sense and sense of personal preservation it is possible.
    Having said that... rims from japan are readily available. And you can also get decent widths, not 6.5 junk. There are several site sponsors on this site, including myself, that are able and willing to import rims for a customer.
    Edit- I do not recommend using this technique, nor do i support unsafe modifications on the road or the track.
    Hope this helps,
    Justin
    Rob
    Moorabbin
    please do not do this reversing modification
    thanks
    Ferny Grove
    agreed
    its doable and the wheel can/will stay intact, however it places alot of extra force on wheel studs, axle brearings, hubs etc
    if you flipped a 6 inch rim you would end up with 4" off the mounting face and 2" inboard, all the force of cornering etc is now placed on that outside 4" section which is past the mount face.
    i wish i had pics
    EDIT: MS PAINT FTW!!!!
    RE EDIT: can't upload paint pics WTF?!?!?
    Stefan
    Parkinson
    SCRUB RADIUS WILL BE AFFECTED ASWELL
  1. 4x Xr4's 15's
    By Grantobius in forum Car Parts For Sale
    Last Post: 19th July 2008, 12:30 PM
  2. Longchamp XR4's, MA61's and some 18's.
    By KonaKid in forum Car Parts For Sale
    Last Post: 29th April 2008, 10:13 PM
  3. Wheels - 15x7 xr4's/MKIIr's and some levin lip
    By rthy in forum Car Parts For Sale
    Last Post: 20th March 2008, 02:17 PM
  4. Xr4's for sale
    Last Post: 28th February 2008, 09:20 PM
  5. Painted XR4's
    By Touge205 in forum General Topics (No Technical Questions)
    Last Post: 4th March 2007, 05:44 PM
