Results 1 to 10 of 15
Thread: 4A toda flywheel, exedy clutch
    Sep 2009
    Boronia
    Forsale:
    Toda flywheel (3.8kg i think) for 4age
    200mm, 3 puck exedy clutch, with exedy pressure plate too.
    Bought off a guy with a 20v sprinter who used them for 10000kms, I havent used it at all. Its just sat in my room.
    Reason for sale, going supercharged so i dont need this anymore.
    Looking to sell them together $500.
    Located in near blackwood, in SA.
    Veteran Bustin_86's Avatar
    Justin
    North-West Coast
    Fffaarrrkkk
    Wish i hadnt of just bought a clutch. This is a fucking steal... grrrr
    You have PM
    Aaron
    In the Mountains
    flywheel wont fit Justin, clutch would though.
    your clutch should be quite similar anyway.
    Rob
    Moorabbin
    Neither the clutch plate nor the pressure plate will fit 3t....
    the bolt pattern is different as are the splines...
    Aaron
    In the Mountains
    im fairly damn sure it would David, if it is 200mm as the advertisement says.
    as i said flywheel wouldn't, spline is the same...
    Charlie
    SE
    so these will fit any 4age engine being 16v,20v,gze?
    Sep 2009
    Boronia
    From what ive been told if you use the matching fly and pressureplate/clutch you can use it on any of them.
    Aaron
    In the Mountains
    yes all of the 8 bolt cranks (100kw 4ag, 20v) will except this flywheel.
    Veteran biggo's Avatar
    Nick
    Noosa
    ah, thanks for clearing that up. :2thumbs:
  1. FS: 4AGZE Exedy racing clutch with flywheel
    By Brent_R in forum Car Parts For Sale
    Last Post: 30th August 2010, 10:06 PM
  2. FS: 200mm exedy clutch, pressure plate, flywheel
    By aeke7086 in forum Car Parts For Sale
    Last Post: 12th March 2007, 04:00 PM
