Page 17 of 22 FirstFirst ... 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 LastLast
Results 161 to 170 of 216
    Senior Member klusio's Avatar
    Kieran
    cheers for the kind words, seemed like the best place to put the oil filter mount mainly getting it to function
    with the direction of flow and sorting out lines etc. should make servicing a bit more pleasant.
    It doesnt have a brace on the outer side as yet will see how it goes, nice and sturdy for the moment though.
    Got the edging from a local rubber supplier called purple pig might be on the BIG island?
    it has an metal inner skeleton bit that helps clip/hold on edges, was all of $1.20 per meter so I bought a good
    length to use through the car, good for tidying holes and sharp edges.
    Cheers Kieran
    Thanks to: Az & me - Azcustom
    John - Davidson Autobody
    Matt - Tasmanian Engine Reconditioning
    Tobias - Koolstik Signs
    4AGTE Powerd AE86 Tassie Spec Build Thread
    Senior Member Dongaz's Avatar
    Cameron
    The Gap, Brisbane
    Just noticed that you have taken off the middle support that holds up the flimsy metal for the hood latch.
    You will more than likely need to make a new support for that like I did so your bonnet will close and lock in. Just a heads up.
    Veteran timbo's Avatar
    Tim?
    Wild West
    Motor and engine bay are so tidy. Really great contrast in colours too!
    Senior Member ae86 drifter's Avatar
    Pete
    seen this car in person.86 porn in the making
    ROYAL GARAGE NEWCASTLE
    Kieran
    Ok guys I'm in need of a 20v TPS plug can anyone help me out?
    If I find one I might even do an update...
    Cheers Kieran
    Kieran
    Also after s series diff housing brackets for rear sway bar, will need to be cut off the housing
    Cheers Kieran
    Jun 2009
    Michael
    Interested to see how the 2871r goes. I run a 2860r on a stock smallport gze but looking to go bigger.. What sort of power are you expecting?
    Kieran
    What rpm do you have full boost? How much power does it make?
    I'm hoping for over 200kw, has port work, cams and over size valves and springs etc.
    Cheers Kieran
    Jun 2009
    Michael
    Pushed it on the last tune and lasted 2 weeks before it lifted the head. Was making 10psi at 3400 and 24psi at 3750. A very driver friendly power band. Power was 210kw on a 50/50 e85 and pump mix. Was down around 180kw on pump 98 and 15psi. Time for headgasket, studs and more e85
    Craig
    Northern Beaches
    my gt2871 4a makes 306hp (230kw) on pump 98 and 340hp (253kw) on pump e85. It has no head work apart from a very quick tidy up of the casting dags, stock cams, valves and springs. I do have ARP head studs and a cometic gasket to keep the head on but.
    ohh yea thats running 18psi and a smallport head.
  1. jap spec 86
  2. jap spec 86
  3. jap spec 86
  4. aus spec 86
