slaves rod sits in the divit in the fork not the hole, also did you check the springs in the pack that they were all sitting in correctly etc etc. There might have been a reason that pin was ground flush. in which case its probably scratching up your fw. As you have dont, start from the top work your way down, its a pita taking gear boxes on and off so try to check everything over before putting it back. But my moneys on the actual pack just been flogged out. Look for cracks etc, clutch kicking and slipping causes the springs to take a fair beating, soemtimes cracks even occur in the plate around them.
