yeah it all looks fine to me, sorry about the way i wrote, my brain goes too quick for my fingers. Just make sure you are fitting it properly, if its misaligned it will do what you described to a certain extent. Check for recent wear from its recent fitment and see if it is even all around. If its thicker or deeper on one section or what ever. Make sure the fork is in the right place, and just try to bleed it as best you can, like get some serious pumping going and make sure you keep plentiful fluid in the reservoir, as they are quite small and can suck air in if the level is pretty low.
