hi,
i need the specs on a 7afe crankshaft, as i am going to get a new one.
i have searched around and found:
bore is 81.0
stroke is 85.5
pistons are 4
is there anything else i will need to add to get the crankshaft made properly? maybe length and flywheel bolts?
i want to put an 8 bolt flywheel so i can run 4age flywheel and clutches.
i basically want a 7afe front crankshaft, with a 4age back crankshaft outside the block
any help is good
