Results 1 to 7 of 7
Thread: adjusting speedo
    hey,
    this is a bit a of noob question but i just go a new diff in and i was woundering who adjusts the speed so it is correct now. like a mechanic or engineer.
    thanks.
    bump
    Should only need to adjust it if you got a diff with a far different ratio to the original... What was the old and new ratios??
    the old was standard s series and unshore off new one pretty sure its stock hulix lsd
    Veteran Konakid's Avatar
    Henry
    Eastern
    Also interested in this as i am changing rear ratio to 4.1
    There is a tech thread on changing speedo drive gears to match new final drives... I could post link but I'm lazy.
    Johnny Rochester detailed all the combinations and had equation for working it out etc. look through his posts.
    Henry
    Eastern
    Winner! chizm
  1. adjusting coilovers
    By japan86 in forum Technical - Questions
    Last Post: 4th November 2011, 03:30 PM
  2. Replies: 11
    Last Post: 30th January 2011, 03:56 PM
  3. Wheel width adjusting...
    By mr04ag in forum Technical - Questions
    Last Post: 28th June 2010, 11:51 PM
  4. adjusting idle
    By VTAZ! in forum Technical - Questions
    Last Post: 10th January 2010, 03:41 AM
  5. adjusting ring's
    By ae86 in forum Cars or Parts Wanted
    Last Post: 20th December 2008, 12:34 PM
