Page 7 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 10 LastLast
Results 61 to 70 of 99
Thread: Intake tuning for your quads
  1. #61
    Anthony
    My only contribution to this topic is to pass on information given to me by someone who has spent many thousands of hours on a flow bench. According to him the magic number for the taper of an inlet tract to the throttle plate is 7 degrees.
    You can take from that what you will, but if you're lucky enough to be including tapered bores in your next big induction project- go with 7
  2. #62
    Ru-iki
    On the topic of bell mouths, I have a friend who is seriously into tuning his wrx. It has a fully custom and immaculately presented turbo steup, which includes a pair of plenum chambers he had made himself, after exhaustive flow bench testing.
    For his setup, he has found offsetting the inlet runners from the chamber to give an angled oval mouth was very effective, not in increasing flow,but in making even airflow from one runner to the next. He claims about 3-4 percent variance in the volume which he can flow from the first runner to the second.
    Secondly, he has exhaustively tested trumpet designs, with the idea he would include them in his plenums, and made a very good point about the bell mouth design. His tests indicated that the rim of the trumpet is one of the most restrictive areas. What his tests have shown is that a large share of the air drawn in to the opening has come from around the lip. So it effectively turns the corner around the bellmouth, up to around 180 degrees and accelerates as it does so.
    I did some basic vacuum tests for myself and was able to observe this.
    There was a lot of air drawing around the lip and very little observed to be straight in and down the funnel.
    To me this means that two things are important.
    - You need an excellent heat shield under the trumpets to allow cold air to be drawn from this location, closer to the heat of the engine, hence my massive tray.
    - You need a smoothly machined lip with no hollow cast underside. i'd like to ee someone machine a teardrop shape on the lip and see some footage of how it flows, I think it would be very very good.
    Once I truly considered why this might happen, Ive come up with a basic theory, and it relates to the pressure difference to the inlet runner and engine bay and surrounding air, of course.
    Air doesn't have to be drawn in a linear sense, when there is a pressure difference between two areas, you will see all the nearby air within the surrounding area attempting to rush to the low pressure area, despite the barriers and obstructions in the way.
    In this case the suction is created by the engines thirst for air.
    Just as with our weather, wind is created by pressure differences and the resulting movement of air in a never ending attempt to equalise pressure.
    I therefore think that even though the air around the trumpet itself and under the bellmouth is seemingly facing a difficult path, its point to point distance may only be a few mm from the low pressure area, therefore its being pulled up around and into the bellmouth by the pressure difference. This air is attempting to make its way into the inlet runner in the same amount of time as the air with an easy path above the the mouth, therefore it accelerates to do so. Air is such a flexible medium that it can be pulled around corners, and with some decent velocity too. Try it for yourself!!
    I know my explanations aren't super scientific, but I though that this was an interesting point which hadnt been made yet, with the discussion focussing on inlet runner length primarily. Feel free to critique my theorys, as I'm always after a new perspective.
    My inlet at the moment...
  3. #63
    Elite rthy's Avatar
    Leo
    Tulla
    <div class='quotetop'>QUOTE (Ru-iki @ Feb 9 2008, 11:04 AM) </div>any chance you can describe this for me more as I don't quite understand
  4. #64
    Ru-iki
    <div class='quotetop'>QUOTE (Sam_Q @ Feb 9 2008, 10:30 AM) </div>any chance you can describe this for me more as I don't quite understand
    [/b][/quote]
    Here is a diagram I made for you in paint. Should explain what I mean...
  5. #65
    Elite rthy's Avatar
    Leo
    Tulla
    oh yeah I get it, thanks for that
  6. #66
    gunbz-r
    anythin ever come of the jelly moulds?
  7. #67
    Elite rthy's Avatar
    Leo
    Tulla
    damn, I forgot to look
  8. #68
    Oldschool Member
    Jul 2006
    For those of you that are looking at ram tubes and the like, I found this site:
    They have bare ram tubes that you should be able to make fit to silvertop throttle bodies. They also have aluminium donuts that you can use to turn the ram tube to clear master cylinders and the like.
    I've ordered some ram tubes and some donuts to make up a set to suit my car. I think they were under $30 each, which is not too bad. Only problem is that you need an AC Tig welder or a mig setup for aluminium.
    Leo
  9. #69
    Elite rthy's Avatar
    Leo
    Tulla
    hey good work, can you post some pics when you get them?
  10. #70
    gunbz-r
    they've got the 50mm ones to theyll fit blacktop throttles for thos who care
  1. WTB: Cash to go - Techno Toy Tuning Quads to Small Port
    By amaroo66 in forum Cars or Parts Wanted
    Last Post: 21st October 2009, 04:24 PM
  2. Replies: 20
    Last Post: 21st February 2009, 12:52 AM
  3. 4ac intake to 4afe intake
    By FUTO_GT in forum Technical - Questions
    Last Post: 30th December 2008, 03:12 PM
  4. putting 20v quads on 4age quads
    By w84me in forum Technical - Questions
    Last Post: 24th September 2007, 09:33 PM
