Got a package in the post today from Elettra.
The trumpets I got are the 49mm x 230mm long versions. They were $54 each. The donuts were $22.50 each.
I did some measurements, and have some numbers for a 16v.
Valve face to edge of the head - 80mm
Average distance* from valve face to outside edge of silvertop throttle bodies with a smallport T3 adaptor - 220mm.
*Average distances are quoted because of the taper and bend in the port
T3 Trumpets are 75mm high.
By my calculations, the ideal length for trumpets is in the 380 - 400mm range, so another 105mm (max) needs to be found. Plan is to chop up the donuts as required to get the bend angle right, then chop down the trumpets to suit and weld it all together.
I've attached some pics for an idea of what you get from elettra. The material is pretty thin, but its only supporting an air filter pod. They look nicely made, and will have plenty of room for me to cut bits off for straight bits. The short trumpet is a T3 item.
Leo
[attachment=22939:tn_DSC00387.JPG]
[attachment=22940:tn_DSC00388.JPG]
