Results 1 to 3 of 3
Thread: coil problems
    Queensland
    hey guys, on the way to archerfeild last night my car shit it'self, i wasnt thrashing it just normal grann spec, it lost all power and just died, i got it towed home in the morning and tried to find the problem, so i got the multimetre out and heres what i found
    primary coil = 1.5 ohms
    secondry coil = 12k ohms
    primary voltage = 6 volts
    #note its a 4ac if that helps#
    there is no spark from the coil, i have no idea whats wrong with it because the coil looks brand new as do all my spark plugs, if this has happend to anyone and could shed some light i would be truly greatful as i really need my car and have no other means of transport
    thank you....
    JOE
    Senior Member shinny's Avatar
    Liam
    the resistances sound right,
    first check all fuses, should be an engine fuse or ignition fuse check them.
    check wires to and from the coil, corosion/loose,
    pull the dizzy cap off and check the points,
    (gf's car had the rubbing block on teh points break off and same deal no spark)
    these are just a starting point,
    ps this should probably be in the tech questions
    Benn
    gold coast
    well all the resistances look good and the voltage is alright, time to check signal, double check the coil by removing the coil wire(one to the dizzy), put it near vehicle earth(a bolt or something) and earth out the coil quickly, it should spark when the earth is removed.
    if not, coil or lead is stuffed, if it does then it's time to start looking at points probably not opening.
  1. How to Wire coil on plugs? 20v ST w/ Aftermarket ECU w/ 4 coil pack
    By Fine Taste in forum Technical - Questions
    Last Post: 5th August 2014, 07:50 PM
  2. Replies: 0
    Last Post: 24th June 2012, 12:57 PM
  3. Replies: 2
    Last Post: 6th April 2010, 12:01 PM
  4. Replies: 9
    Last Post: 3rd January 2010, 12:20 AM
  5. More problems
    By LordNafe in forum Technical - Questions
    Last Post: 17th August 2007, 09:55 PM
