well all the resistances look good and the voltage is alright, time to check signal, double check the coil by removing the coil wire(one to the dizzy), put it near vehicle earth(a bolt or something) and earth out the coil quickly, it should spark when the earth is removed.
if not, coil or lead is stuffed, if it does then it's time to start looking at points probably not opening.
