You'll need to track down a sandwich plate, there's two types, the plain sandwich plate which pretty much spaces the filter and then there's the relocation kit. You have to work out which you would like first. With either ones the oil run from the sandwich plate, filter, cooler (I think) and then back to the sandwich plate then so on, just like it would without a cooler. Same sequence just the section from where it enters the filter and returns to the block is longer.
