Results 1 to 8 of 8
Thread: Possible pinging
    AE71 Rolla
    Smile
    I'm having some issues with my engine because the moment i come on boost(i know i'm not supposed only being 100km old) it start's to ping it's head off.
    Now i'm pretty sure my timing is set on 10deg BTDC so could it be that the ECU might need resetting.
    Also the oil pressure gauge goes from 85psi(too high yes?) down to about 78psi. :blink: it always used to rise before i rebuilt the engine so what could be causing this problem?
    Any help appreciated
    andrew
    pretty shaw or defentily shaw
    pinging could be bad or old fuel.
    when does the oil pressure go down ?
    my oil pressure cold will be at 7 bar then when its hot it will go under 1bar
    when its hot as soon as i rev it it will get bulk oil pressure
    AE71 Rolla
    I've checked that the mark is right and it's spot on.
    Yeah 85 cold. i took it for a drive tonight actually for about 20mins and it didn't drop. yesterday it went down to about 60psi on idle after about 25 mins :unsure:
    It varied from 10 to 15 at 800rpm
    I put a fresh tank in just before i went for a drive about 20 mins ago
    It only goes down on idle after about 25 mins
    AE71 Rolla
    No, i never have. It ran fine in my 71 and my 86 before it blew up.
    andrew
    with the oil pressure it could be the pressure relief valve stuck shut and not letting it bypass.
    and for pinging did you use a thinner headgasket ?
    AE71 Rolla
    Where about's is the relief valve?
    I used a genuine ZE one
    andrew
    in the timing cover near oilpump you gota take sump off theres a circlip in the cover inthere is the spring and valve.
    AE71 Rolla
    I cleaned that out spotlessly so there is no way it could be getting stuck
  1. Detonation/pinging
    By 70rolla in forum Technical - Questions
    Last Post: 15th November 2011, 12:11 PM
  2. 4AGE Silvertop Lean and Pinging?
    By sloth in forum Technical - Questions
    Last Post: 13th August 2010, 11:21 PM
