Results 1 to 10 of 14
Thread: MISFIRE
    Stuart
    Nsw
    i filled it up with fuel and drive down the road about 1km and starts missing so i pulled over and it stalls. i try to restart it but it won't run for more than a few seconds. i open the fuel cap and fuel poors out. lucky i live down hill from where i broke down so i was able to coast it home. i tryed removing some of the fuel. and ran it again but still its missing. i find that one of the leads is in a bad ways and i'm not sure if this is the problem or it is fuel related. has anyone had a similar problem. the cars is a ae86 with a AFM GZE with front mount, it doesn't have a surge tank. just a HP pump. it was running fine before. anyone got any clues to solving the problem.
    Ryan
    qld
    brisbane
    Aust.
    probably dodge fuel. empty it as much as you can, and go buy some premium stuff, chances are it will be fixed.
    Senior Member Lost Prophet's Avatar
    Canning Vale
    When i had just completed my conversion i had a problem similar to this.
    It was caused by a blockage/restriction in the return line for the fuel, it had heaps of pressure in the fuel rail and when the pressure regulator opened it would not return due to the blockage, the spark plugs would foul and it would miss until it would not fire at all. Have a look to see the state of your spark plugs. Also had a dodge ignition lead. Check these things out, because from what you have described it sounds like what i had.
    Good Luck
    Stuart
    Nsw
    i'm gunna drain the fuel this arvo and blow out the lines and the rail and see how it goes. i'm gunna take a fuel same to the servo also. thanks for the help.
    anyone have a pic of where this fuel return line is? , cause my engines playin up and couldnt hurt to try this, i think witchity solved his problems by blowing this out.
    Stuart
    Nsw
    i drained out all the fuel but it's still missing i think it might be the dodgey lead. so i'm gunna do plugs and leads. what plug gap to people run with a GZE.
    Stuart
    Nsw
    so i tryed plugs and leads. it drove fine for about 20 minutes then started with a slight miss and it just kept getting worse. i'm gunna try a fuel filter but i'm not hopeful. does anyone know how you can test a gze AFM.
    Canning Vale
    I dont know how to test the AFM but it definately sounds like its running rich and fouling plugs. Mine does exactly the same.
    Have you looked into things like an O2 sensor? (if you dont already have one)
    Check to see how much fuel pressure is in the rail. Someone here should be able to tell you how much it should be. I think its about 400 - 450 MPa.
    If its extremely high and stays that way you have a return line blockage. I made what used to be the fume return the return line. Its bigger and has almost solve my problems. Just needs a tune now.
    I would go as far as to say its definately a fuel issue.
    callum
    qld
    tully
    maybe crank angle sensor. ( affected by heat) or the fuel pump. i had similar problems. ( spluttered after like 20min of driving then conked out. after it got hot the fuel pumps shat themselfs then i waited for a few minites and it ran good for a while, then the same thing. replaced the fuel pumps and it fixed the problem.
    your friendly neabourhood electrition. for cash jobs pm me!
    Stuart
    Nsw
    thats interesting callum1 i will try to get a gauge on it some how. i have a gauge but it has a fitting for a tyre valve type fitting on the fuel rail. do you just fit a T peice in the supply line and then conect the gauge.. i checked the O2 sensor and wiring and they look ok.
  1. 16v misfire
    By BlueLevin in forum Technical - Questions
    Last Post: 1st December 2011, 02:28 PM
  2. Misfire, cyclinder drop at idle and on partial load - 22RE
    By Konakid in forum Technical - Questions
    Last Post: 27th August 2010, 11:31 AM
  3. 4AGE misfire and crap idle
    By lach in forum Technical - Questions
    Last Post: 9th April 2010, 02:37 PM
