Results 1 to 8 of 8
Thread: What tailshaft?
    as topic....just put a tseries in my mates car...tailshaft doesent mach up...i heard t18 is the way to go...
    anyone know?
    thanx
    Adam
    Jay
    does it have a t50 in it? can remember about ke70 but in ae86 u use front half and then the rear needs to be a jdm one or t18 because its slightly short allowing it to fit
    Rust is a way of life
    Dave
    if its stocko ke70, it will have a 4K motor, with either a K40 or a K50 gearbox. to put a T series diff in, you need to leave the front half of the trail shaft, and just replace the rear half with one from a T18.
    - Blaise Pascal
    the tailshaft is a single piece...i mean it bends in the middle but cant be seperated
    its got a 4k in it
    Veteran driftism's Avatar
    Andrew
    Watsoia
    if it's a stock ke70 with a 4k you need a custom tailshaft for it.
    I ran into this problem when i fitted my lsd diff to my ke so i could have some fun while the sprinter was being built. pity i forgot about the tailshaft not fitting until i had fitted everything else.
    bugger that sux...yeah thats when we figured it out....after everything else was done..might just have to redrill the tailshaft
    Veteran biggo's Avatar
    Nick
    Noosa
    you need to shoten it. redrilling will cause the input to smash the gearbox bearing/seal
    i found its actually about 10 mm too short hmmmm
  1. Replies: 3
    Last Post: 13th September 2011, 08:56 PM
  2. What tailshaft?
    By jdm_510 in forum Technical - Questions
    Last Post: 28th August 2009, 09:06 AM
  3. tailshaft
    By wiltoi in forum General Topics (No Technical Questions)
    Last Post: 14th April 2009, 07:53 PM
  4. tailshaft
    By todd in forum Car Parts For Sale
    Last Post: 29th May 2008, 08:59 PM
  5. tailshaft
    By 4awagon in forum Technical - Questions
    Last Post: 22nd January 2007, 02:10 PM
