Results 1 to 10 of 14
Thread: wats this brake bias thing when doing a jdm
    cheers
    Jay
    U need either a JDM brake bias valve or a adjustable one like this
    Rust is a way of life
    but why??
    but why??
    Elite rthy's Avatar
    Leo
    Tulla
    because the original drum braes require a different preload to work than a disk setup. However your original brake bias adjuster is fine with a small modification. Look here:
    brake bias means how much braking is done by the front VS the rear, if it was equal the rear would lock up first because of the reduced weight and loading.
    30kw club
    so what does this thing look like and where is it??
    Elite rthy's Avatar
    Leo
    Tulla
    ok its an ugly little block of cast iron under the brake master. Heres how you find it:
    look at your master cylender and folloe the two brakes lines coming off it and they will go into this thing. A picture is on my accoustics page.
    BTW its my personal opinion that a trueno disk brake rear end its really much of an upgrade
    30kw club
    i just wanna use genuine 86 rear calipers on my f series thats why im finding out bout it!!
    Oldschool Member
    Sep 2007
    has anyone put adjustable brake bias controller on a car with standard brakes does playing with it improve your braking performance set up properly much or are they normaly set up pretty good from factory?
    Elite rthy's Avatar
    Leo
    Tulla
    you cant install a bias adjuster to limit the front braking, only to limit the rears. The stock sprinter could use more rear bias if oyu ask me but you cant easly do it.
    30kw club
  1. JDM brake bias valve and T peice NEEDED
    By BARWICK in forum Cars or Parts Wanted
    Last Post: 11th October 2011, 10:11 PM
  2. JDM brake bias block
    By 86 Nick in forum Cars or Parts Wanted
    Last Post: 20th August 2007, 05:45 PM
  3. WTD JDM AE86 brake bias valve
    By Crostek in forum Cars or Parts Wanted
    Last Post: 19th July 2007, 08:07 AM
