front and rear springs are the same on most Xx to Ax model falcons. Rates are different tho slightly.
Cut in half, invert and put in rear of 86 voila!
Hey all
I've searched through and read a fair few threads on this subject. But i'm still clueless.
Can someone tell me.. Which model falcon springs fit into the ae86. And what goes where.. how much you can/need to chop?
Mate of mine has given me a set of koni springs from his EL falcon. But i'm not too sure if they will fit and if so.. does the rear springs go int he front or what?
Thanks all!
dont use them, ive got them in my 70 and my brothers 71 and they are shit, just buy a proper rated spring
^^they are ok considereing you can get a full set from the wreckers for 40$ or less.
but dont even think about putting them in without short stroke/better shocks
it'll handle like crap...
- Blaise Pascal
Yer all rebound and no bound is wak...
Get seirra rear shocks and something decnt for the front too. basically the setup i use, i hear alot of people saying use one half of a spring for the rear, but i really cant see that going down well. They need the proper flat tops to sit in correct or else they just wont work.
Not sure on model, but see if you can look at your current struts or some spare ones, get a measuring tape out and measure the seat and the spring hat, then go to a wreckers with those measurements. Just use what springs you can find will fit, i think El springs might fit, but just measure them first.
i have EA falcon springs in the rear of my ae71 mated to SW20 short stroke shocks. Never had a problem with them, still slides perfect. Good cheap upgrade but still dodgy, i don't plan to keep them in there long term.
-zac
How do you have SW20 shocks in the rear of a 71?
sorry for the noob question; but grant, can you elaborate on "all rebound and no bound is wak." what does this mean?
as far as falcons go in the rear, i have them (with Gabriel shocks) and say for example i jack the car up, and have the car stands on the chassis rails , the wheels only drop a further 10mm at most. i also find going over even half large speed bumps, it feels like the rear got airborne, like it got thrown over it, there is absolutely no give (or absorption of bumps, if you like to put it that way, its rock solid)
is this good / bad? i personally dislike it as id rather a little bit of absorption to account for shitty roads etc etc
my shocks were cut in half, so their free height is 220mm.
of course its bad, i hope you mean your springs not your shocks were cut! ive got one au spring cut in half for the rear of my brothers car, yea its low and whatever but the ride is shit and thats with sierra rear shocks, maybe it does work if they are longer, but i think you should just get 6kg, it might still be harsh but alot better than no suspension travel
