Results 1 to 6 of 6
Thread: how wide will my ke70 front wheels sit
    Nic
    Mt Evelyn
    well i dont want to modify the s13 LCAs so just wondering how far the front wheels will sit out compared to standard. i will be running ma61 rims. great if anyone has some pics too.
    Nic
    edit: i didn't read the question properly and gave you the wrong answer
    Greg
    Coorparoo
    well.. as far as i remember... the S13 LCA's are 20mm or so longer.. so.. you'll gain 40mm in track (20 either side), and maybe 5-10mm in the offset of your wheels.
    bueno. theres your answer.
    The wheels should still be in the guards. just. you may need to roll the lip up a bit i'm not sure of the width/offset of MA60 rims
    also, if they're 14's.. you have to use CA brakes (250mm rotors), not the later SR brakes (280mm rotors) because they will only fit under select 15's.
    Veteran dr1ft-pig's Avatar
    Brendan
    NORTHSIDE YO
    you gain 60mm in track (30mm each side) according to gillys article
    so from where the bottom of your wheel sits now measure 30mm out and that should be around where itll sit, wont be exactly accurat but will give u an idea
    MY JZX83 (clicky)
    Nic
    Mt Evelyn
    ok sweet. thanks for all the help.
    is it the same stud pattern?
    Brendan
    NORTHSIDE YO
    yes
    MY JZX83 (clicky)
  1. Replies: 30
    Last Post: 4th July 2012, 10:40 PM
  2. wide 13 wheels mk2
    By jakel in forum Cars or Parts Wanted
    Last Post: 8th April 2011, 08:53 AM
  3. Wheels - How wide can you go?
    By jet111 in forum Technical - Questions
    Last Post: 26th November 2010, 02:29 PM
  4. wide wheels on wagon!!
    By john84ie in forum Technical - Questions
    Last Post: 1st September 2010, 12:30 AM
  5. WTB: 14 or 15in wheels 7-8in wide
    By (Locky) in forum Cars or Parts Wanted
    Last Post: 20th July 2009, 09:41 PM
