wat spring rate are u running, the clock sound i think has sumthign to do with the spring itself knocking on the seats or sumthign, but im nto sure, i think it might be normal though dpending on yoru type of coilover
Hi guys.....as topic.
i find my car are too stiff on the front, you can feel every bits of the road even on OK road the car still bounce like a hard plastic round ball.
And very often i can hear a "Clock" sound. so is it normal??
my camber is neg
the the of coz is lowerd but as low as some of you guy( with low Origin still off the 10cm+)
camber tops?
yes i have camber top and i this Neg camber add on too....
not to sure what brand or what spring rate it is!!
i import this car from japan,..so i dont have much idea most things
sounds like loose bearings in the camber tops, or the shocker nuts are a bit loose, tighten them up and see.
i second that
my camber top nut (shock nut) comes loose on the drivers side every fortnight
i don't have access to a rattle gun so i just retighten it religiously
Could also be the nut that holds the insert tight in the strut tube. If that nut comes loose, it will cause the insert to move up and down when you hit bumps in the road causing a clunky/clock sound.
-Alex
I'd put my money on that too. Mine seems to come loose every now and again (I think the passenger side one is slightly loose ATM). To test, jack the car up on the side the noise is coming from so that you can easily see the strut tube. Have a feel of the the nut on the outside of the strut, and tighten it up. Good maintenance idea![]()
4AGE is here! Cheers 44GTE and Anthony for your help! http://www.ae86drivingclub.com.au/fo...ad.php?t=10384
AE86 Driving Club Official Rules -please read!
What am I doing right now? Twitter me!
i got the same thing in the passenger rear....lol still have not checked it yet maybs 2moro
well, if the cars still bouncy as, and making knocking noises...
your shocks are blown![]()
