Page 3 of 3 FirstFirst 1 2 3
Results 21 to 26 of 26
Thread: new bling
  1. #21
    Veteran driftke70's Avatar
    Ryan
    Buderim
    could probably just get a standard one put a sheet of acrylic or perspex over it and chuck it in the oven at like 110 degrees for about 15 mins. Then just trim it and drill some holes.
    wheelfriends.wordpress.com
  2. #22
    Adan
    Oxley Park
    its kinda like that.
    i doubt it would work without a handy dandy vaccum former though.
  3. #23
    Veteran dori_86's Avatar
    Jaidan
    Adelaide Hills
    so did u just vacuum form over a standard plastic 1? or did u make a mold out of wood first? also did u cover the front ribs/vents so it was flat? also what size plastic r u using to get the detail? cos i've thought it would have to be HDPE = High Density Polyethylene as its got a moulding temp of around 120oC and a average deforming heat of around 90oC and i was unsure if that would be ok for engine bay temps?
    sorry for all the questions as i sort of do things like this at uni so ive been slowly been thinking about how to do it
  4. #24
    Veteran dr1ft-pig's Avatar
    Brendan
    NORTHSIDE YO
    man if you would make a full set for a 20v, man i really got no idea wha i would do to get my hands on one, pure secks
    MY JZX83 (clicky)
  5. #25
    Adan
    Oxley Park
    for this one i vacuum formed over the original. it turned out ok.
    i only did at work cause i was bored, it is by no means high quality.
    im not sure what kinda plastic it is, but we buy it specifically for vacuum forming.
    i didnt heat it up too much, so some of the curves arent too good, and the ribs didnt show either.
    i plan to try another one and make it neater, doing it over the original cover might actually work well with the right prep
  6. #26
    Jaidan
    Adelaide Hills
    well if u get desperate i have access to a couple of vacuum forming machines at uni 1 is big enough for most regular sized products etc and another is sometimes used but refrigeration companies cos its that big
  1. Bling v8 commy wagon
    By hachi6 in forum Cars for Sale (Not Toyotas)
    Last Post: 12th August 2009, 06:54 PM
  2. KE70 and KE55 Bling - Rare Treasure
    By LittleRedSpirit in forum Car Parts For Sale
    Last Post: 17th March 2009, 08:20 PM
  3. Project Bling
    By riojin in forum General Topics (No Technical Questions)
    Last Post: 24th July 2007, 05:36 PM
  4. Bling your 86!
    By Poobrown86 in forum Toyotas in the Media
    Last Post: 1st June 2007, 07:27 PM
  5. Bling Tail Lights
    By krumpet in forum General Topics (No Technical Questions)
    Last Post: 16th August 2006, 04:25 PM
