Results 1 to 10 of 10
Thread: help me diagnose this noise...
    Senior Member riceburner's Avatar
    hi guys, well as we all no, our cars are old and they creak and make strange noises..
    ive got one thats a little weird.. basically it comes and goes, tends to be more prevalent on bumpy roads and when im in a gear too high (ie in 4th when i should be in 3rd etc). it comes from the area behind the gearbox (so the tailshaft/under the centre console type area)
    its a weird knocking noise that i originally thought was just the pax seat wobbling, but it isnt. ive looked underneath but cant seem to see any areas of contact or anything loose..
    any ideas?
    Insert witty comment here....
    Veteran v-tec's Avatar
    Grant
    Gold Coast
    Could be your exahaust is hitting the frame underneath, i have that in my 71 when the is kicking to the right it will knock just under the passanger seat. It could be doing this on yours just after where the cat is.
    Other than that maybe a bearing or something in your tailshaft?
    Ferny Grove
    how low is your car??
    if its pretty slammed i know what the problem is
    Senior Member Lost Prophet's Avatar
    Canning Vale
    ^^^^^ Is the answer coming?
    I have an extremely similar problem but its when i go over bumps, it feels like something is trying to bash through the bottom of the car <_<
    The kind of noise you prepare for coming up to every bump.
    Sorry to hijack but i think its probably the same problem.
    oh and my car is fairly low.
    Veteran dr1ft-pig's Avatar
    Brendan
    NORTHSIDE YO
    tailshaft hitting body
    MY JZX83 (clicky)
    nah not low at all...its lowered but not much away from std...
    Nov 2005
    fill your diff with diff oil.... when its low it makes a knocking sound
    thats what i had in my s series diff
    Senior Member gumbie's Avatar
    Jordan
    Sunshine Coast
    From the position of the noise you are describing it sounds to me as if your tail shaft centre bearing is on the way out.
    Check the condition of the rubber around the bearing.
    Nick
    Veteran GAKI86's Avatar
    Dave
    Broady
    by anychance thos car u speak of was white with a wolf 3d?
    yes its the bearings.. i cbf fixing that thing.. had that car 3 years ago..
    ^_^
    pair rusty trueno guards
    2x trueno headlights
    pair trueno guard indicators
    rally zenki trueno front bumper
    kouki trueno front bumper
    zenki flip grill
    2x trueno grill
    pair zenki ae86 seats
    Billy
    vic
    Templestowe lower
    most of the time the rear shocker is hittting the body, which will make that noise too
    u can get someone sit at the back seat, and get off the plastic cone cover. go over bump and see the shocker hit or not
  1. 4agze diagnose box
    By smackdown.exe in forum Technical - Questions
    Last Post: 20th April 2012, 07:36 PM
  2. Suspension noise
    By Shitbox in forum Technical - Questions
    Last Post: 24th March 2011, 11:04 PM
  3. Diff Noise
    By Fusion in forum Technical - Questions
    Last Post: 1st October 2009, 10:19 PM
  4. Help Diagnose my AE71
    By jim8o in forum General Topics (No Technical Questions)
    Last Post: 11th April 2007, 11:29 PM
  5. squelling noise
    By ae86 slide in forum Technical - Questions
    Last Post: 7th September 2005, 09:38 AM
