Results 1 to 10 of 20
Thread: 8 Inch rims + tyres
    Senior Member patience's Avatar
    Iain
    Alderley
    Hi guys, just a quick question before I go and order some tyres for the new rims.
    Will 225/50/15 fit on the rear of a sprinter, on an 15x8 inch rim with around a 0 offset, without any guard mods? The suspension is a little lowered, but nothing dramatic or major.
    Or should I get 205/50/15?
    What do you think I would be better off getting?
    Btw, I'm NOT going 195/50/15 on an 8 inch rim
    Cheers guys, any help would be appreciated.
    Veteran blair's Avatar
    Blair
    SEQ
    i have 14x7's with -9
    so fairly close to 8's with 0.
    stretching 165's over them, im still worried about them hitting the guard over a big bump (with pritty stiff springs n shocks)
    oh and its lowered to bout tyre meeting guard level.
    i reckon yours will fit with a slightly bigger tyre...
    but u will deffs have to cut away/bend up the inner bit of the arch lip thing
    hope i helped.
    <div class='quotetop'>QUOTE (patience @ Nov 1 2007, 12:34 PM) </div>225/50 will probably rub on gaurds even if you roll them because of the increased width/profile hence over diameter being bigger and they will bulge on 8's and look homo.
    What is your aversion to 195/50's on 8's??? AE86 is a light and that tyre is capable of proving plenty of grip up to 200 hp provided you get decent tyres (not cheap crap) otherwise please don't go any bigger than a 195/55 or 205/50, it will look like a tractor!!! And 8's 0 offeset will need rear lip rolled (Seen Superlites 15x8 -4 195/50 AOK)
    Rob
    Moorabbin
    <div class='quotetop'>QUOTE (winslow @ Nov 1 2007, 01:51 PM) </div>
    please put 185s on your car
    185/45 R15 yo Nankang NS2 - oops you want 14's
    Iain
    Alderley
    Basically as the 195/50s are only rated to 7inch max. I won't be drifting the car so I don't want stretch or whatever, it will be for grip/daily purposes, so I don't want the tyre popping off or failing.
    I'll be running Toyo T1Rs.
    I'm leaning away from the 225s now
    <div class='quotetop'>QUOTE (741 @ Nov 1 2007, 01:29 PM) </div>225/50 will probably rub on gaurds even if you roll them because of the increased width/profile hence over diameter being bigger and they will bulge on 8's and look homo.
    [/b][/quote]
    Jul 2009
    Kane
    Coburg
    205/50/15 would be perfect for your needs
    T1Rs have very mixed reviews, there are far better tyres available for similar $.
    Also 195's will not pop off 8's - I use 215/45s on 9s on my daily - no worries
    Iain
    Alderley
    <div class='quotetop'>QUOTE (chapl @ Nov 1 2007, 01:46 PM) </div>Thanks mate, thats what I needed to hear.
    I'll give the T1Rs a go, my tyre shop (Keith 4 wheels) are a very good bunch, and recommended them over the new Adrenalins and other tyres.
    I'm getting the 195/50s for $150 each balanced and fitted, so can't complain
    Senior Member DavisJD's Avatar
    yeh id reccomend the 205/50 as well.
    It may rub on your guard depending how low it is.
    Id reccomend rolling your guards as a bit of a safeguard.
    See how they fit first though.
  1. 13 inch tyres
    By ke.slider in forum Cars or Parts Wanted
    Last Post: 4th October 2010, 03:25 PM
  2. Replies: 0
    Last Post: 12th June 2010, 05:03 PM
  3. WTB 14 or 15 inch rims and tyres
    By ke25 racer in forum Cars or Parts Wanted
    Last Post: 21st September 2007, 06:00 PM
  4. WTB 13 inch rims (10 inch or 8 inch wide)
    Last Post: 5th June 2007, 08:14 AM
  5. 14 inch - TYRES ????
    By ROSCO in forum Technical - Questions
    Last Post: 12th April 2007, 09:03 PM
