Results 1 to 8 of 8
Thread: ae/ke diff axles + other Q's
    Senior Member resol's Avatar
    steve
    vic
    need a little help. i more then likely have a bent rear left hand axle in my wagon (dont ask). and need to find a replacement asap,so my questions are:
    - are left and right hand axles the same?
    - are sedan diffs (axles) the same as wagon diff (axles). the wagon diff's are leaf and dont have panhard/swaybar mounts, so the outside of the housings are different, but are the axles interchangable?
    and a little off topic (to get the most from this thread...)
    what shocks/springs would be good for a daily drifter. thinking sierra in the rear, and not sure up front (will have ra40 struts up front). going to runs an extra (flipped) leaf in the rear which will hopefully do the trick, at least initially. was thinkin of getting some custom 6 or 7kg front springs made up for the ra40 struts?
    -cheers.
    P.S. i need this car on the road by next weekend for work...
    gunner:
    ALL DRIFT MODIFICATIONS
    Veteran anastasios's Avatar
    Taz
    Earlwood
    im guessing you have a 70? i personnally dont like sierras in the back for daily driving, good for drift but very harsh for sydney roads
    steve
    vic
    i have a ae71 wagon, for interests sake. the rear shocks are shorter then stock sedan shocks also.
    gunner:
    depends how much shorter they are
    but in general...sierras suck! they are way to short for sedans, this is at a usable height, not dragging along the ground (140mm to the jacking seams or so)
    there is a thread in the tech artices about rear suspension, have a look in there
    i recommend the lowered commondor wagon shocks, they work good for me
    - Blaise Pascal
    Aaron
    In the Mountains
    as far as the axles are concerned i believe that they have a leaf sprung s-series the same as sprinters..?
    if this is correct than ke70/ae71 sedan axles will not fit.
    just remember that its not quite as essential for your shocks to be matched perfectly to the shocks as far as hight is concerned because your leafs aren't going to pop out i hope.
    really you just after something with a heaver valving..? commo shocks are a decent bit stiffer then std ones and about 2"? shorter then the sedan ones.
    i sold some TRD adjustable blue shocks to a guy with a ke55 (leaf rear) and he seems quite happy with them, they are normal stroke to, probaly doesn't help you much but yeah.
    Elite rthy's Avatar
    Leo
    Tulla
    this thread should be moved to technical questions
    30kw club
    steve
    vic
    yeh cheers sam.
    **mods could this thread please be moved?**
    <div class='quotetop'>QUOTE </div>from what i have been told/seen for myself the diffs in the ae/ke wagons are the same as in the sedans - other then the external mountings - . mine is a borgy, and the backing plate off a sedan is currently bolted to the rear of the housing. there is an ae71 wgaon at the wreckers with a diff it it, but its missing the left hand axle (how anoyingly ironic). so really only needing to know if the right hand side will work in the left hand side.
    as for rear shocks im going to go ahead and fit the leafs in and measure how low they make the car then buy shocks accordingly. i'd prefer short stroke since the leafs wont be having much movement once i add an extra one (upside down).
    thanks for the replys.
    and again, could mods please move this thread....my bad
    -resol
    gunner:
    Site Supporter Javal's Avatar
    Josho
    <div class='quotetop'>QUOTE (resol @ Nov 4 2007, 06:45 PM) </div>Ok.
    <div class='quotetop'>QUOTE (ae71 @ Nov 5 2007, 12:24 PM) </div>Wrong on the first one, right on the 2nd.
    The AE71 WAGONS have the same diff as the sedan (borg-warner), however it is leaf sprung so the mounting points are different, but that is all.
    The AE71 PANEL VANS have the same diff as an ADM sprinter (S-Series), so obviously the axles from a regular AE71 or KE70 won't fit.
    <div class='quotetop'>QUOTE (resol @ Nov 5 2007, 02:46 PM) </div>from what i have been told/seen for myself the diffs in the ae/ke wagons are the same as in the sedans - other then the external mountings - . mine is a borgy, and the backing plate off a sedan is currently bolted to the rear of the housing. there is an ae71 wgaon at the wreckers with a diff it it, but its missing the left hand axle (how anoyingly ironic). so really only needing to know if the right hand side will work in the left hand side.
    -resol
    [/b][/quote]
    Word, thread should be moved, as for diff differences, read up.
  1. Need ke diff or ae open 4.11 ratio
    By 70rolla in forum Cars or Parts Wanted
    Last Post: 14th June 2011, 04:27 PM
  2. corolla love affair (ke's/ae's)
    By driftae71 in forum General Topics (No Technical Questions)
    Last Post: 7th December 2007, 10:11 AM
  3. ke and ae's with lockers
    By grape_moosha in forum Technical - Questions
    Last Post: 16th January 2007, 12:09 AM
