Page 14 of 21 FirstFirst ... 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 LastLast
Results 131 to 140 of 206
Thread: What do you use to initiate?
  1. #131
    Veteran Konakid's Avatar
    Henry
    Eastern
    Well there kinda of is, if someone is chasing you, you can use the speed to pull a big lead on them as opposed to them coming in slow and just kicking the clutch to try and catch up.
    I just reckon its awesome fun to do because you know that if you werent on the brakes to slow the car down while sideways you just wouldnt be able to stop in time for the corner. Surely that has to be the fastest way to enter?
  2. #132
    Member D4NI3L's Avatar
    Jun 2009
    Daniel
    Croydon
    you didn't really read that at all did you,
    i had a commodore for 2 years.
    for the first 6 months i used the handbrake.
    and every month i used it i wore out shoes.
    so i changed the shoes about 6 times......
    now that your caught up to everyone else
    Life is best spent \\Sideways//
  3. #133
    Jun 2009
    Daniel
    Croydon
    and then you say
    if your going in over speed, and then braking very hard, there is no point in you going in over speed.
    haha omg you dont even know what a braking drift is do you
    if you go in to slow you can't brake hard enough to get the weight transfer to the front then you end up understeering into the corner
    if you go into the corner faster and brake harder you get enough weight transfer to the front then as you turn in (by the way still going alittle to fast for the corner) you tap the brakes once more not to slow down but to lock the rear wheels remember all the weight is on the front wheels so even the lightest touch on the brakes will make the rear tyres lock it slide
    basicly if you go in fast you have the grip if you go in slow you dont
  4. #134
    Senior Member kaibeecee's Avatar
    Pete
    doesn't a VX commo have ABS?
    so.... how does this work again?
  5. #135
    Veteran Robo86's Avatar
    Rob
    dude dont go having a dig at driftke70, he knows 100x what you do, and is a very good slider himself.
    +1 on pete
    http://shirtstuckedin.com/
    my corolla
    Bosman Wholesale Tyres
    3274 5374 - Roy
  6. #136
    Jun 2009
    Daniel
    Croydon
    yeah you just need to pull the wiring harness to the ABS computer in the engine bay abs light on to have fun
  7. #137
    Jun 2009
    Daniel
    Croydon
    his been haven a go at me sence i got here i consider it closed now
  8. #138
    Veteran driftke70's Avatar
    Ryan
    Buderim
    i understand what your trying to say about weight transfer, i just dont like commodores
    wheelfriends.wordpress.com
  9. #139
    Veteran blair's Avatar
    Blair
    SEQ
    ^ and almost every persons attitudal problems that owns one.
  10. #140
    Ryan
    Buderim
    you said what i was hoping was passed on
