Page 3 of 3 FirstFirst 1 2 3
Results 21 to 23 of 23
Thread: Spring Rates
    Rob
    Moorabbin
    no worries mate
    ALL of my springs are rate tested BEFORE being sent out so no issues
    i keep the majority in stock
    also i can send you some bridgestone re001s $27 a tyre to ship if you are keen, ill do you cost on the tyres
    they are awesome
    email me at
    i also found the 2 of 4 setting on the whiteline front to be spot on. 1 also am using 8kg/6kg with kyb agx shocks.(cheers lawson). the only thing i found with the whiteline sway bar was that tyres rub due to the bar coming over the castor rod where as the trd sway bar goes under the castor rod.
    but it's like sam said what works for some won't always work for others
    Veteran Konakid's Avatar
    Henry
    Eastern
    <div class='quotetop'>QUOTE (Mech`s Blue @ Nov 11 2007, 01:29 PM) </div>Noice, will have to check to see if mines rubbing, cheers.
  1. Spring rates?
    By lappy in forum Technical - Questions
    Last Post: 31st July 2011, 03:08 PM
  2. Harder spring rates, ride height and compressed rates.
    By Breaka in forum Technical - Questions
    Last Post: 13th November 2009, 01:12 PM
  3. Spring Rates
    By Dan_AE86 in forum Technical - Questions
    Last Post: 12th October 2007, 04:24 PM
  4. Spring rates
    By thekid in forum Technical - Questions
    Last Post: 17th November 2005, 02:16 AM
  5. spring rates
    Last Post: 12th September 2005, 09:02 PM
