Page 3 of 3 FirstFirst 1 2 3
Results 21 to 28 of 28
Thread: TODA for my car
  1. #21
    Site Supporter Javal's Avatar
    Josho
    <div class='quotetop'>QUOTE (KonaKid @ Nov 9 2007, 01:28 AM) </div>Is that the Fours and More diagnosis?
    [/b][/quote]
    Oh, like i said, craig is back spotting Initial D hair salon every day, and working on Jags, Triumphs and Magnas.
    But he is right.
  2. #22
    hey, i just recently changed my spark plugs to iridium ones and ignition leads (custom 20V ones)
    its been running good for about 1 week now, but its starting to sound like a boxer? and it will stall if i idle (400 - 500 rev range)
    my friends say im running on 3 cylinders and other friends say that its the spark plugs? coz i changed back to the ignition leads i had in before and it still does this.
    any help please?
  3. #23
    Veteran Bustin_86's Avatar
    Justin
    North-West Coast
    Put a timing light onto it and see if its missing on any cylinders, could be a fouled plug, might need a higher temp rated plug.
  4. #24
    Veteran biggo's Avatar
    Nick
    Noosa
    few tips from a fellow bt20v owner
    plugsa usually last me 10 000kms, FWIW i just chuck in normal ones. Iridium will get the same life.
    I use mobil 1 5w-50, but i do alot of hard driving every week (think 200kms uphills hitting 8500rpm) and usually get 2500-3000kms out of my oil.
    there really is nothing wrong with the motor as standard except for its lack of torque down low. Provided with your upgrades itll only get worse unless you run a stupidly high diff ratio
  5. #25
    Senior Member 350hp4agte's Avatar
    underwood
    qld
    jimboomba
    Iridium's are gay they fowl up real easy use normal plugs i had the same problem also
  6. #26
    Veteran mc68's Avatar
    Feb 2011
    Andy
    Subo
    <div class='quotetop'>QUOTE (Nikkojoe @ Nov 8 2007, 12:16 PM) </div>Worn Valve seals cause blue smoke, not piston rings
    [/b][/quote]
    nikko, either way its burning oil and oil = blue/white smoke
    stem seals will let oil into the combustion when its idling for a while OR been sitting not ran, then on start up it will blow smoke...
    it does sound like the oil is getting past the rings
    that brings me to my next thing.
    You say you have the $$$ to build this motor..
    to get 10k rpm you really have to be doing some special things, i am no expert BUT at those revs you have to worry about oil startvation..and will need a dry sump. A crank that is balanced and is one grind short of being a michael angelo masterpeice lookwise also....
    fancy japanese parts wont mean anything is unbreakable...and the people who run engines to that sort of speed usually have sponsors and an hour metre on the donk...
    seems to me you just want to reach the end of your tacho....well maybe slot it into 2nd when your in 5th on the fwy!
    as for the ecu, find who the tuners are in your city, see what they WILL tune, see what they have used before, with diferent applications (they know more than people on a forum)
    not saying dont try it...just expect it to be alot harder than pistons, cams and a timing belt.
    Andy.
  7. #27
    Site Supporter Driftspec's Avatar
    Keating
    Caboolture
    Guys... its oil burning during combustion. Needs a general service and rings change, and that should get rid of most of the smoke.
    Mate if the car sounds like a Boxer engine, you are running on 3 cylinders. Duck under the hood and make sure that all the plugs are connected properly, both on the engine and the ignitors. That will solve it :2thumbs:
    4AGE is here! Cheers 44GTE and Anthony for your help! http://www.ae86drivingclub.com.au/fo...ad.php?t=10384
    AE86 Driving Club Official Rules -please read!
    What am I doing right now? Twitter me!
  8. #28
    Elite rthy's Avatar
    Leo
    Tulla
    <div class='quotetop'>QUOTE (jcae86 @ Nov 8 2007, 02:40 PM) </div>what are the specs of the cams?
    why did you get toda gear exactly?
    You know seeing you have bought the pistons have considered some spool rods?
    make sure you find a decent engine builder when you put it together.
    oh and also you will want to look at blueprinting the engine, porting it, obviously a balance, angled intake manifold spacer, top notch extractors, list goes on
  1. TODA dealer???????????
    By DODGENG in forum General Topics (No Technical Questions)
    Last Post: 20th February 2012, 09:06 PM
  2. Replies: 15
    Last Post: 19th May 2011, 12:58 PM
  3. TODA 4age flywheel
    By todd in forum Car Parts For Sale
    Last Post: 15th July 2009, 02:37 AM
  4. Toda itbs
    By damo46 in forum Technical - Questions
    Last Post: 22nd April 2008, 07:38 PM
