<div class='quotetop'>QUOTE (Sam_Q @ Nov 9 2007, 06:59 PM) </div>bummer dont have a rattle gun. y do u recommend using one? or is it just easier.
whatever you do use a 6 sided socket and a rattle gun
then I highly recommend getting one with a compressor. Rattle guns by the way they work undo/do up bolts by a series of shock loads which doesnt lend itself to rounding off a bolt the way a progresive load will. I cant explain well but a breaker bar will always round off a bolt before a rattle gun will.
Does every else agree?
yes i do sam.
and steering arm to the cross member?...wtf...you mean steering rack i hope.
<div class='quotetop'>QUOTE (Sam_Q @ Nov 9 2007, 07:09 PM) </div>
ah ok, how much does just the rattle gun cost?
What ever you want to spend....
Dirt cheap ones from under $100 to the sky is the limit ie around $200/$400![]()
400? try $750 for a snap on 1/2" one
or $1500"+ for cheap 3/4 and 1" ones
get a full inch gun! weigh 25kg and sound like a light truck![]()
dam well that what you get when people buy you presents then lie about the costs![]()
now that i think about it, 2nd hand may of been couple yrs ago![]()
just get a cuting disc on a grinder and slice a line in the top of the bolt and take it out with a flat blade driver may work
Just dont use multi-sided sockets. 6 point socket FTMFW! If you round a bolt with a good qualit one of these your doing something wrong.
