Results 1 to 10 of 11
Thread: 4age bigport to 20v silvertop
    i was thinking of moving up and i thought 4age and 20v engine brackets would be the same since the bottom end is supposed to be the same ?,
    well i just wanted to make sure and do they use the same loom ? im a bit lazy and dont feel like taking all the loom out and inputting another set im not too fussed about fitting 20v manual ecu
    david.
    Senior Member Fozz's Avatar
    Nathan
    Gold Coast
    <div class='quotetop'>QUOTE (w84me @ Nov 11 2007, 11:31 AM) </div>Did u research this conversion it is alot of work?
    engine brackets are the same
    No the bigport loom does not fit 20v
    is it really alot of work ? is there an easy way of fitting the loom like cutting 4age loom down and adding the 20v differences in or what ?
    Elite rthy's Avatar
    Leo
    Tulla
    better off removing the bigport loom and putting in a 20v loom or aftermarket ecu loom
    Nathan
    Gold Coast
    <div class='quotetop'>QUOTE (w84me @ Nov 11 2007, 11:47 AM) </div>Are you talking about the whole conversion in general about being alot of work of just the loom?
    No that wpuld be way to much effort for what its worth just get the 20vloom
    Nov 2005
    If your bigport loom is really neat and looks OEM then it would be a shame. but if you chop them both to fit each other your destroying two looms there.
    make a 7age20v instead lol
    im poor =( so 20v loom is a hard job ? cause if so i might as how much is it to get the loom professionally fitted
    gunbz-r
    go buy a 20v comp and harness, why use 16v bottom end when u can use all 20v stuff don't waste ur money and do it right
    converion cost me a touch under $3k incl. blacktop comp harness everythin bar stacks for the throttles. DO IT RIGHT!
    =\ yeah i dont have that sort of money i can get the hole setup farily decent price but like im wondering if its hard to DIY or how much it iis to get it done professionally
    Veteran dr1ft-pig's Avatar
    Brendan
    NORTHSIDE YO
    stick with your bigport and replace bottom end with a 7afe bottom end, thus making it a 7age, will go hard as heaps more torque
    MY JZX83 (clicky)
  1. [VIC] 20v silvertop 4age!
    By khoala in forum Car Parts For Sale
    Last Post: 18th November 2009, 07:16 PM
  2. 4AGE 20V Silvertop Parts
    By Polaris in forum Car Parts For Sale
    Last Post: 18th February 2009, 05:32 PM
  3. 4age 20v Blacktop vs Silvertop
    By shelldrake in forum Technical - Questions
    Last Post: 4th June 2008, 02:09 PM
  4. 20v 4age silvertop
    By sheldonmcg14 in forum Car Parts For Sale
    Last Post: 20th January 2008, 10:54 AM
  5. 4age 20v silvertop.
    By superbmobile in forum Car Parts For Sale
    Last Post: 24th September 2007, 12:05 AM
