oh car still drives fine no difference have drivin it since for about 3 or more hrs.
well i got my diff welded yesterday and drove on the freeway for about 2hrs straight after and then all of a sudden within 2 mins it went from silent to a fnk loud whineing grinding noise i pulled ofer checked it had oit yep it did i decided to change oil on the side of the m1 noise was still there i have been told by 1 person its my
-wheel bearings from pressure from the locker
another person its my gear box cos it only does it from 60km/h on and only in 3rd and 4th gears (4 speed box)
and another pesoon it is my pinnion wheel
please if u can help doo.
any one?
when you changed your oil, did it have lots of metal shavings in it?
my locker makes a pretty loud noise at certain rpm, speeds etc.
well can you go higher then 60kph in second gear?
to be honest i reckon its the pinion gear thats been warped or something.
it wont be the bearings as that theory would imply that the bearings would be providing resistance, and the locker has removed that resistance. the rotational force at that point would have no effect on the bearings, regarding the force the locker is applying to the axle.
no no metal shavings and the noise is worst on 1/4 to half throttle there is no noise on no throttle and a little bit out full throttle and its gets worse the faster i go
Sounds very similair to mine. As ryan said, you may have warped something from he welding, but if the cars drives fine then it should be ok. Mine has done this since i got it and I haven't had any issues with it whatsoever.
My money's on crown and pinion issues. My diffs whine like pigs (yes, even the stock, open S series).
Turn the stereo up and ignore it. It may break one day, but then again you welded your diff so you'd have to expect that.
Borg warner fruit salad!
Yep crown wheel is fucked, mine did exactly this, took it out for a t series after 20,000 kms of thrashing, still works fine.
RT142 Estate.
AJPS.
