well after getting my car dynoed and tuned for some retarded reason i only put out 80kw with 500nm of torque? so i guess my first question is, this is not normal as far as i know? most people can get about 120kw with the same sort of mods these being ECU front mount, exhaust, injectors pump etc. So before cutting all losses and putting an SR in I want to put a bit more boost into it, now i guess there is a few options, I could ditch the SC pulley and put something smaller on, then this will get rid of the relay too, but... will this then make my car constantly under boost? or is this controlled by the ABV? I'm not too familiar with superchargers, then my other option is bigger crank pulley, which then overdrives the water pump too? then last but not least, who knows of companies that make pulley kits? i have seen the nevo kit, and read something a while ago about a place in adelaide called RPM that made them too and found another company in america that does a kit and i guess the way our dollar is would be a good option too.
anyway thanks heaps guys
