1- Torque readings from dynos are wrong. Unless you enter ALL the relevant things (diff ratio, gear ratio, tyre size etc). You get a far better idea assuming 100Nm per litre. And adjust for the boost pressure. Therefore stock 8psi on a 1.6 litre will give around 260Nm.
2 - I doubt 115rwkw at stock boost with stock cams. Yes the dyno readout may say that, but what it makes in reality may be a different matter. Out of interest, at what revs are peak power and peak torque, and what do the AFRs look like through the revs?
