Ok people,
First off in todays sale is a pair of rear G4 coilovers to suit an AE86. These have been used in my gf's daily AE86 and worked great. They have a good range of height adjustment and also are damper adjustable. They also feature solid bottom mounting points (no rubber).
Down side is upon removal i have noticed oil leaking from both shocks. So your probably best off to change the shocks if you have a problem with this. They are still very drivable as shocks still seem to work fine and gives the car a firm feel. I am unsure of the spring rates but a second pair of springs will come with the coilovers. The spares are rated at 9.8kgs. :crazy:
These coilovers would best suit the low budget weekend drifter looking to be able to play with there rear height adjustments, from standard to super slammed.
Price: $390 + postage ($40?)
Next i have front G4 camber tops in perfect working order. These were also used on my gf's daily 86.
Theres not really much to say about camber tops, there camber tops that adjust camber and are in perfect condition.
Get that much needed camber you've been wanting!![]()
Price: $170 + $15 postage.
Lastly i have a G4 front coilover conversion kit that was used on my gf's AE86.
Once again these items are all in perfect working condition with only a few scratches.
The threaded sleeves fit perfectly over the standard 86 struts and hold firmly with grub screws.
Quick and easy installation that will give you the choice of adjusting your front ride height as you like.
Price: $220 + $20 postage.
All items have been removed from my gf's car purely because she has bought a new 86 and i am converting her old one back to stock. Watch out for other goodies i will be posting up in the next day or two![]()
All items located in Melbourne. Pick up available.
