Results 1 to 5 of 5
Thread: Turbo Question
    Site Supporter Javal's Avatar
    Josho
    Hey guys.
    Didn't want to make it public knowledge but i am thinking about dropping a V8 into my car and turboing it.
    I got to thinking about it and how in efficient even turbos are (compressor efficiencies of about 80% at best).
    Since a turbo's function is to pressurize incoming air and force it into the upper motor, and turbos are driven by high pressure exhaust gas created from the combustion process, couldn't I just bypass the turbo altogether and route my headers back into the throttle bodies?
    Since I have CFI, I could balance the DEI (direct exhaust injection as I just coined it) by feeding one header into each throttle body. Yes, the charge air wouldn't be that cold, but it would be under a hell of a lot more pressure.
    I attached a quick sketch below:
    There are still a few things I need to work out:
    1) What kind of gearbox should i use behind this lethal combo?
    2) What pinion angle should I use in my rear-end? I'm sure there will be a noticeable difference in torque output...
    Adapted from another forum, NOT Toymods.
    I lol'd
    This can probably be moved to Offtopic / Jokes.
    Veteran slide86's Avatar
    Huw
    Hills
    dude WTF.
    you had me going for a minute there
    Josho
    <div class='quotetop'>QUOTE (slide86 @ Nov 14 2007, 12:50 AM) </div>That's the idea, fool.
    Veteran Konakid's Avatar
    Henry
    Eastern
    You obviously werent at the Ed tonight, plenty of flavour bitches there to keep you occupied...
    damn the internetzzz
    Josho
    <div class='quotetop'>QUOTE (KonaKid @ Nov 14 2007, 12:59 AM) </div>Was at the exeter, good company / cheap drinks FTW.
  1. WTB: 4AGE High mount Turbo mainiold - to suit T2* turbo.
    By maxhag in forum Cars or Parts Wanted
    Last Post: 18th October 2011, 12:18 PM
  2. Replies: 8
    Last Post: 24th July 2011, 11:46 PM
  3. Quick clutch question and spigot question
    By wideslider in forum Technical - Questions
    Last Post: 9th August 2008, 12:45 AM
  4. Turbo question
    By ae86dave in forum Technical - Questions
    Last Post: 27th August 2006, 03:02 PM
  5. Turbo question
    By in forum General Topics (No Technical Questions)
    Last Post: 1st January 1970, 11:00 AM
